#750639 by Pete
25 Jul 2010, 10:31
You may also still have a local cache of the page, or an ISP cache. Probably worth giving it 24 hours before final judgement on any speed improvement.
For me, in Safari, the lack of the footer bar does feel faster.
#750648 by Jacki
25 Jul 2010, 11:12
Seems quicker on Safari. y)
#750651 by pjh
25 Jul 2010, 12:09
Not sure whether this is related or not, but from this a.m. when I;
- first access the site I am logged out
- log in I get an "invalid token" message
- then hit the browser (IE7) back button I am logged in
Paul
#750653 by mitchja
25 Jul 2010, 13:01
pjh wrote:Not sure whether this is related or not, but from this a.m. when I;
Paul
Yes, I'm getting the same here this morning as well. Using Safari 5.0 for Windows here.
#750659 by honey lamb
25 Jul 2010, 13:39
I don't notice any change. I'm using Safari 5.0
#750666 by DragonLady
25 Jul 2010, 14:21
Thanks Pete.
Much better for me too- the stretching of text and "boinging" effect has stopped. There is still a bit of a time lag when scrolling through posts though.
DL
#750739 by Neil
26 Jul 2010, 07:59
Pete,
With the removal of the whole of the bottom bar, how are we notified of PM's now then? Is it just via email/checking manually, as the little envelope with the red number in the bottom bar was how I was always aware.
#750741 by DragonLady
26 Jul 2010, 08:22
Neil wrote:Pete,
Any chance of the electronic roar that used to happen when a pm was received coming back?
DL
#750742 by Pete
26 Jul 2010, 08:42
I'll look into writing some kind of alternative PM notification
#750743 by pjh
26 Jul 2010, 08:44
This has been sorted. :)
#750752 by Pete
26 Jul 2010, 09:37
Yup - probably should have mentioned it, but beat the Invalid Token problem with a very large stick, and hopefully it won't be back ;-)
Working on an alternative toolbar and/or PM notification system now.
#750753 by Alex V
26 Jul 2010, 09:53
Cant say i notice much difference with the speed today still takes the usual 3-4 seconds to load a page.
cheers
alex
#750761 by Pete
26 Jul 2010, 10:24
You may notice a couple of odd page errors this morning while I'm tweaking the site code. Normal service will return asap...
Pete
#750762 by Pete
26 Jul 2010, 10:30
Now added a new version of the bottom toolbar that doesn't rely on the chat code (so none of that overhead), plus also can be collapsed if you want it out of the way.
#750820 by Hamster
26 Jul 2010, 21:59
I can't view photos! It comes up with the loading graphic but does nothing...
Thought I would try and be helpful and let you know.
#750830 by Pete
26 Jul 2010, 22:37
Hamster wrote:I can't view photos! It comes up with the loading graphic but does nothing...
Yes, I see what you mean. I suspect it's a knock-on effect of the new version of the toolbar. That's the problem with software, you fix one thing only to discover it doesn't play nice with another part of the code.
I'll look into it and try and find a fix.
Pete
#750832 by Pete
26 Jul 2010, 23:04
Ok, photos fixed. It was an incompatibility with the new footer bar, so the simple solution was to turn off the footer bar on gallery pages.
#750853 by David
27 Jul 2010, 08:51
The "boinging" is back for me this morning. Anyone else ?
#750854 by pjh
27 Jul 2010, 08:57
Not noticed that particularly, but;
- I see a footer bar is back
- I am unable to update my status
As Private Eye would possibly say, are these two perchance related? :D
#750855 by Neil
27 Jul 2010, 08:59
pjh wrote:Not noticed that particularly, but;
Yes, Pete has created a new footer bar which doesn't use the chat code, so won't cause the problems like before. The footer bar can also be collapsed if you don't want it, but it is used to notify when a PM is received.
#750865 by pjh
27 Jul 2010, 10:11
Neil wrote:Yes, Pete has created a new footer bar which doesn't use the chat code, so won't cause the problems like before. The footer bar can also be collapsed if you don't want it, but it is used to notify when a PM is received.
Still can't update my Profile Status :w
Users browsing this forum: No registered users and 38 guests
