#242 by Pete
10 Feb 2004, 00:36
Now that the Glossary is online so you can lookup some of the semi-technical language used on VirginFlyer, this has also been incorporated into the forums so matches from the Glossary will be highlighted with a dotted underline and a tool-tip pop-up window will appear with the definition when you roll over the text.
An example of this is V.Touch, which when you roll over that text will explain what it means.
This only applies to new postings from today, and only where the case matches (to avoid to many mis-matches of context).
Pix
