#7743 by Gavin
04 Sep 2005, 23:36
Hi
Do you know of any of the Upperdeck PE seats are allicated on check in, I have recently booked a flight to MCO on 8oct and was unable to reserve any seats on the upperdeck - they were all showing as booked. I really want to sit up there as i heard it is better, will I be able to get 2 seats if i check in online 24 hours before?
Gavin
#75859 by preiffer
04 Sep 2005, 23:40
There are 4 (2 x 2) Exit row seats that are allocated at check-in (unavailable using Online Check-in) only.
There are also another 4 (2 x 2) Bulkhead seats at the very front of the cabin. These would also be allocated by VS only (and I think cannot be pre-selected using OLCI also, ISTBC though...?)
Basically, if it says none of the others are available, you may have to chance it on the day at the airport. It is however worthwhile checking every now and then, as people move/cancel from time to time. Doesn't hurt to keep trying... ;)
#75860 by Gavin
04 Sep 2005, 23:43
WOW that was a quick reply- I love this site :D Suppose I will have to keep checking to see if any seats are moved- or get to the airport Early!
#75877 by paul_a142
05 Sep 2005, 09:57
preiffer
Sure your right regarding the bulkhead seats at the front.
We're booked upstairs in January and when I did the seat res those 4 on the bulkhead plus the 4 on the exit rows were greyed out.
regards
#75878 by FamilyMan
05 Sep 2005, 10:02
Seats 70AC at the front upstairs is a skycot position. I do not believe this is true of 70HK.
Phil (Buffy)
Users browsing this forum: No registered users and 166 guests
