#162875 by AlanA
09 Mar 2007, 14:17
Left it a bit late haven't you?
The Hilton is OK, not as good as it used to be. Gone downhill in my estimation. that's why I have booked the Sofitel for December to see if its any better.
#162889 by stuart101
09 Mar 2007, 16:16
I prefer the Hilton, Ok, it is an airport hotel, you will never get anything that fancy, but i does what it says on the box so it is fine for 1 night.
#162890 by andrew.m.wright
09 Mar 2007, 16:24
Sofitel every time or failing that the Premier Travel Inn across the road from the Sofitel is nice if all you need is a bed & shower.
Last time I used it it was £60 a night ... The Sofitel was over £100 via holidayextras.co.uk
BTW DON'T buy drinks at the Sofitel Bar ! It will leave your wallet more empty than the current Upper Class Amenity Kit [^]
#162896 by porsche911
09 Mar 2007, 16:50
Cheers guys - Alan , sorry I should have stated that when we go we have to go the night before - Its not till June but I just want to book something in advance - Cheers
#162908 by DragonLady
09 Mar 2007, 19:51
Keith,
The Hilton is fine and ideal if you're using a carrier that flies from the South terminal (like VS).The rooms are standard Hilton fare, ie nothing objectionable.The exec rooms are a bit more plush but IMHO not worth the extra money (but OK as a HH perk).Beware of the bar prices though - they must be in cahoots with the Sofitel (or just purely taking advantage of happy minded travellers off on their travels)
Julie
#162921 by MarkJ
09 Mar 2007, 20:47
The Hilton is attached to the South Terminal and the Sofitel to the North.
So it depends on whether you want a little trip to check in or a walk over the bridge!
There are all sorts of deals for both hotels - b&b, dbb etc
#162961 by The_Banking_Scot
09 Mar 2007, 23:52
Also if you are an HH member , you get 1000 VS miles with the Hilton ( if you book with Hilton).
Of course you may get a cheaper rate booking elsewhere.
TBS
#163010 by andrew.m.wright
10 Mar 2007, 22:46
Originally posted by DragonLady
Keith,
Julie
Ah someone else whose been stung :D just under 8 pounds for 2 beers at The Sofitel [V]
#163273 by porsche911
13 Mar 2007, 15:38
Well that is expensice indceed - but towards Dublin , not too far off the mark.
#163314 by MarkJ
13 Mar 2007, 21:22
Looks like you were on the beer when you wrote this!![}:)]
