#20756 by p17blo
21 Aug 2007, 03:52
Does anyone know what restrictions are currently in place for set downs at Gatwick North Terminal?
Also what is the latest regarding hand luggage. I believe it reverted back to clear plastic bags after the 'car bombing' at Glasgow. I don't know if it ever reverted back again
#181627 by slinky09
21 Aug 2007, 05:05
I must confess to not knowing what a 'set down' is, however I travelled through LGW on Saturday (North terminal) and normal one hand baggage rules are in place - no clear plastic bags evident.
#181630 by locutus
21 Aug 2007, 08:59
I believe it's the way you are deposited at the airport entrance, ie. being set down outside the terminal. Restrictions were put in place to make BAA money make you use the short stay car park instead of a drop off/pick up point.
#181640 by ChuckC
21 Aug 2007, 12:41
If that is true, it would follow the restrictions put in place at LAX and various other US airports in the immediate wake of 9/11, to further reduce likelihood of vehicle bombs.
Chuck-
#181641 by ade99
21 Aug 2007, 13:47
As far as I'm aware there's been no change at the north terminal. There's still a line to get up the ramp in the early mornings to departures but otherwise they have left the north terminal alone thankfully. It's at the south terminal where they're changing it all around.
#181658 by slinky09
21 Aug 2007, 21:55
OK thanks - on Saturday I was 'sat down' on the ramp at the north terminal and so 5 yd walk right in ... have a good trip
#181660 by buns
21 Aug 2007, 22:15
I can confirm this, I dropped someone off last week at the North Terminal and there is no change - unlike South Terminal where the upper level is now closed[n]
#181737 by p17blo
23 Aug 2007, 09:19
Thanks for the feedback. Yes by 'Set Down' I was referring to a terminal drop off.
#181865 by Roxy-Popsy
23 Aug 2007, 23:52
Our eldest daughter works airside at Gatwick North & tells us if regulations have changed & she has said nothing in the past few days.
Do be aware that you can't finish a bottle of water/soft drinks/ coffee IN the queue for security at Gatwick North. You have to leave any drinks just before you START to queue.
