#247420 by TF
23 Jan 2007, 23:17
A/C G-VFIT Dancing Queen
This is the first time I have used the VS24, usually preferring VS8 or VS20 to come home from CA. First impressions are that the late departure makes for a significantly softer impact on the body clock -probably famous last words.
Used OLCI which worked fine and, LAX traffic apart, whisked through the airport. Boarding started 2000 for a 2105 departure, allowing us plenty of time to get settled on board VFIT, which is running with the old PE seats at the moment. Having flown out on new PE, the improvements on the new seats are very clear. Interestingly, given comments on being unable to see TV on the new seats when the passenger in front reclines, I found this problem was significantly worse on the old seats.
We pushed back at 2050, so were ahead of time the whole way, arriving 20 minutes early at 1540. This was despite taking a longer routing over Idaho and Alberta rather than the usual Dakota/Manitoba route in order to avoid a heck of a lot of turbulance. The CO commented that other aircraft had a 'significantly worse time than us' on the way over last night. Well played VA on that one.
Onboard, there were several op-ups, but missed out this time (Some you win, some you lose...). Crew service was classic early VA - very professional and very fun. My only grumble is the food on VA out of CA. By comparison with food ex-LHR the quality is still very low.
Overall, a good flight, with plenty of peaceful [|)] thanks to the routing.
#391565 by tallprawn
23 Jan 2007, 23:44
Hi TF,
Thanks very much for the report. My trip back from SFO earlier this month provided the fastest flight time I have had back from CA and probably the best food I have had from the west coast also..[:D]
Isn't it great how things can change on a daily basis...[:p]
Glad you had a good flight....[:D]
#391569 by Scrooge
24 Jan 2007, 00:25
Nothing like a good tailwind to help you on your way.
Last month we took a very northern route up over Greenland and north Canada to avoid the bumps and bad head winds, it looks like this yeah is shaping up to be a ad one in that regards.
#391663 by DMetters-Bone
24 Jan 2007, 14:34
Good to read that you had a good flight, and that the service as it should be. [y]
Dominic
#393100 by Mavrick
01 Feb 2007, 09:13
Good TR, thank you. [:)]
Users browsing this forum: Google [Bot] and 52 guests
