#880136 by nkp85uk
12 Aug 2014, 14:50
Which aircraft will you be on? If you're on an A330-300 you will have a USB socket that you can plug your charging lead into. If you're on a B747 or and A340 you will have an empower socket and will therefore need the adaptor
#880139 by mitchja
12 Aug 2014, 15:29
VS do have a few empower adapters on-board still as I saw one handed out on a recent flight. The pax was using it to power their iPad.
#880154 by gumshoe
12 Aug 2014, 20:16
Bear in mind the at seat power can only be used to power devices while you're using them, not to charge them.
You may well find the supply isn't strong enough to charge an iPad anyway.
